[PATCH 5/7] Fixed BASE variable in common.make
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Jun 19 21:32:47 UTC 2015
The BASE variable was changed from $(TOPDIR)/target -> $(TOPDIR) as the "target"
directory's contents were moved to the $(TOPDIR).
 main/make/common.make | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/main/make/common.make b/main/make/common.make
index 161ae77..b12780d 100644
--- a/main/make/common.make
+++ b/main/make/common.make
@@ -8,7 +8,7 @@
 # Various relative directories used to build the monitor:
-BASE		= $(TOPDIR)/target
+BASE		= $(TOPDIR)
 CPUDIR		= $(BASE)/cpu/$(CPUTYPE)
 ZLIBDIR		= $(BASE)/zlib
 GLIBDIR		= $(BASE)/glib
2.3.3
More information about the umon-devel mailing list
