[PATCH 6/7] Renamed linker script templates in BBB port to match BBB target
Jarielle Catbagan jcatbagan93 at gmail.com
Fri Jun 19 21:32:48 UTC 2015
* Renamed CSB740_boot.ldt -> BEAGLEBONEBLACK_boot.ldt
* Renamed CSB740_ramtst.ldt -> BEAGLEBONEBLACK_ramtst.ldt
 ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt   | 63 ++++++++++++++++++++++++
 ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt | 59 ++++++++++++++++++++++
 ports/beagleboneblack/CSB740_boot.ldt            | 63 ------------------------
 ports/beagleboneblack/CSB740_ramtst.ldt          | 59 ----------------------
 4 files changed, 122 insertions(+), 122 deletions(-)
 create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
 create mode 100644 ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
 delete mode 100644 ports/beagleboneblack/CSB740_boot.ldt
 delete mode 100644 ports/beagleboneblack/CSB740_ramtst.ldt
diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
new file mode 100644
index 0000000..c8bc089
--- /dev/null
+++ b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
@@ -0,0 +1,63 @@
+/* CSB740_boot.ld:
+ * This is the memory map file used for the boot-flash based version
+ * of MicroMonitor.  The only value that should be considered adjustable
+ * here is the base address of the 'dram' memory block.
+MEMORY
+	rom :	org = ROMBASE, 	len = ROMLEN
+	dram :	org = DRAMBASE,	len = DRAMLEN
+SECTIONS
+	.text	:
+		boot_base = .;
+		rom_reset.o(.text)
+		*(.glue_7t)
+		*(.glue_7)
+	} >rom
+	.data	:
+		*(.data)
+	} >rom
+	.sdata	:
+		*(.sdata)
+	} >rom
+	.sdata2	:
+		*(.sdata2)
+	} >rom
+	.rodata	:
+		*(.rodata)
+		*(.rodata.str1.4)
+	} >rom
+	.got	:
+		*(.got)
+	} >rom
+	.bss	:
+		bss_start = .;
+		atag_space = .;
+		. += ATAGSIZE;
+		end_atag_space = .;
+		*(.bss) *(COMMON)
+	} >dram
+	.sbss	:
+		*(.sbss)
+		bss_end = .;
+	} >dram
diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
index 0000000..76fbce4
--- /dev/null
+++ b/ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt
@@ -0,0 +1,59 @@
+etheraddr   		= MACADDRBASE;
+alt_tfsdevtbl_base	= ALTTFSDEVTBLBASE;
+MEMORY
+	rom :	org = RAMTSTROMBASE,	len = RAMTSTROMLEN
+SECTIONS
+	.text	:
+		boot_base = .;
+		ram_reset.o(.text)
+		*(.glue_7t)
+		*(.glue_7)
+	} >rom
+	.data	:
+		*(.data)
+	} >rom
+	.sdata	:
+		*(.sdata)
+	} >rom
+	.sdata2	:
+		*(.sdata2)
+	} >rom
+	.rodata	:
+		*(.rodata)
+        *(.rodata.str1.4)
+	} >rom
+	.got	:
+		*(.got)
+	} >rom
+	.bss	:
+		bss_start = .;
+		atag_space = .;
+		. += ATAGSIZE;
+		*(.bss) *(COMMON)
+	} >rom
+	.sbss	:
+		*(.sbss)
+		bss_end = .;
+	} >rom
diff --git a/ports/beagleboneblack/CSB740_boot.ldt b/ports/beagleboneblack/CSB740_boot.ldt
deleted file mode 100644
index c8bc089..0000000
--- a/ports/beagleboneblack/CSB740_boot.ldt
+++ /dev/null
@@ -1,63 +0,0 @@
-/* CSB740_boot.ld:
- * This is the memory map file used for the boot-flash based version
- * of MicroMonitor.  The only value that should be considered adjustable
- * here is the base address of the 'dram' memory block.
-MEMORY
-	rom :	org = ROMBASE, 	len = ROMLEN
-	dram :	org = DRAMBASE,	len = DRAMLEN
-SECTIONS
-	.text	:
-		boot_base = .;
-		rom_reset.o(.text)
-		*(.glue_7t)
-		*(.glue_7)
-	} >rom
-	.data	:
-		*(.data)
-	} >rom
-	.sdata	:
-		*(.sdata)
-	} >rom
-	.sdata2	:
-		*(.sdata2)
-	} >rom
-	.rodata	:
-		*(.rodata)
-		*(.rodata.str1.4)
-	} >rom
-	.got	:
-		*(.got)
-	} >rom
-	.bss	:
-		bss_start = .;
-		atag_space = .;
-		. += ATAGSIZE;
-		end_atag_space = .;
-		*(.bss) *(COMMON)
-	} >dram
-	.sbss	:
-		*(.sbss)
-		bss_end = .;
-	} >dram
diff --git a/ports/beagleboneblack/CSB740_ramtst.ldt b/ports/beagleboneblack/CSB740_ramtst.ldt
index 76fbce4..0000000
--- a/ports/beagleboneblack/CSB740_ramtst.ldt
+++ /dev/null
@@ -1,59 +0,0 @@
-etheraddr   		= MACADDRBASE;
-alt_tfsdevtbl_base	= ALTTFSDEVTBLBASE;
-MEMORY
-	rom :	org = RAMTSTROMBASE,	len = RAMTSTROMLEN
-SECTIONS
-	.text	:
-		boot_base = .;
-		ram_reset.o(.text)
-		*(.glue_7t)
-		*(.glue_7)
-	} >rom
-	.data	:
-		*(.data)
-	} >rom
-	.sdata	:
-		*(.sdata)
-	} >rom
-	.sdata2	:
-		*(.sdata2)
-	} >rom
-	.rodata	:
-		*(.rodata)
-        *(.rodata.str1.4)
-	} >rom
-	.got	:
-		*(.got)
-	} >rom
-	.bss	:
-		bss_start = .;
-		atag_space = .;
-		. += ATAGSIZE;
-		*(.bss) *(COMMON)
-	} >rom
-	.sbss	:
-		*(.sbss)
-		bss_end = .;
-	} >rom
2.3.3
More information about the umon-devel mailing list
