First run of removing code specific to CSB740/OMAP3530 and replacing it with that of BBB/AM335xin BBB port
Jarielle Catbagan
jcatbagan93 at gmail.com
Tue Jun 23 01:09:14 UTC 2015
Hi Ed,
Yes, I wasn't satisfied with the first set of 16 patches so I restarted.
The order of patches are the set of 7, and then the set of 13. I hope that
makes sense. Please let me know if I should clarify further.
On Jun 22, 2015 6:02 PM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
> Ok, I'd like to get started here, but quite honestly, I'm not sure which
> patches I
> need to pay attention to. Jarielle, if I read through this stuff
> correctly, it appears that
> you emailed a set of patches, but then restarted with a new set.
> If that's the case, how do I (keep in mind my "newness" with git) know
> which patches
> I need to review and which ones I can skip over?
> Am I correct to assume that the first patch (and then ~20 following) is
> PATCH [1/7] here::
> https://lists.rtems.org/pipermail/umon-devel/2015-June/000046.html
> These set of patches is the first run of removing code that are specific
>> to the CSB740/OMAP3530 and
>> replacing it with that of BBB/AM335x in the BBB port. Applying all
>> patches in this series does
>> not break the build process of the boot version of Umon.
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150622/f958c7c8/attachment-0002.html>
More information about the umon-devel
