Still undergoing attempt to boot Umon from SD
Ed Sutter ed.sutter at alcatel-lucent.com
Mon Jun 29 15:11:57 UTC 2015
> On Mon, Jun 29, 2015 at 5:25 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
>> Jarielle,
>> I second Chris' comments...
>> Great work and summary of what you've done.
>> Some comments embedded; but basically, I agree with your investment.
>> Let me know which one you get, so if I end up following in your footsteps
>> we'll learn from the same tool.
> Being that this will be my first time using a JTAG debugger I wanted
> one that was cost-effective as well as easy to set up with the BBB, I
> did some research and the one I ended up getting was the Flyswatter2
> which can be found here:
> http://www.tincantools.com/JTAG/Flyswatter2.html.  I also got the JTAG
> adapter kit in order to connect the BBB to the Flyswatter2 which can
> be found here: http://www.tincantools.com/JTAG/BeagleBone-Black-JTAG-Adapter-Kit.html.
> They also have a wiki on how to set up the JTAG debugging with the BBB
> http://www.tincantools.com/wiki/Flyswatter2_BeagleBone_Black_How_To
> I have to admit that this will be a learn-as-I-go process.
Hey, can you tell me something that you've done that (on the first
attempt) *wasn't* a
"learn-as-I-go" process?  :-)
If you don't like that mode of work, you may want to change your major!
LOL!!
PS...
I'll take a look at this debugger, and maybe pick one up myself...
Thanks for the pointers.
More information about the umon-devel mailing list
