Still undergoing attempt to boot Umon from SD
Jarielle Catbagan jcatbagan93 at gmail.com
Mon Jun 29 15:22:20 UTC 2015
On Mon, Jun 29, 2015 at 8:11 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
>> On Mon, Jun 29, 2015 at 5:25 AM, Ed Sutter <ed.sutter at alcatel-lucent.com>
>> wrote:
>>> Jarielle,
>>> I second Chris' comments...
>>> Great work and summary of what you've done.
>>> Some comments embedded; but basically, I agree with your investment.
>>> Let me know which one you get, so if I end up following in your footsteps
>>> we'll learn from the same tool.
>> Being that this will be my first time using a JTAG debugger I wanted
>> one that was cost-effective as well as easy to set up with the BBB, I
>> did some research and the one I ended up getting was the Flyswatter2
>> which can be found here:
>> http://www.tincantools.com/JTAG/Flyswatter2.html.  I also got the JTAG
>> adapter kit in order to connect the BBB to the Flyswatter2 which can
>> be found here:
>> http://www.tincantools.com/JTAG/BeagleBone-Black-JTAG-Adapter-Kit.html.
>> They also have a wiki on how to set up the JTAG debugging with the BBB
>> http://www.tincantools.com/wiki/Flyswatter2_BeagleBone_Black_How_To
>> I have to admit that this will be a learn-as-I-go process.
> Hey, can you tell me something that you've done that (on the first attempt)
> *wasn't* a
> "learn-as-I-go" process?  :-)
> If you don't like that mode of work, you may want to change your major!
> LOL!!
Hehehe! :-)
> PS...
> I'll take a look at this debugger, and maybe pick one up myself...
> Thanks for the pointers.
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
