patches
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Jun 30 02:29:06 UTC 2015
Hi Ed,
git could not apply the patch.  I tried "git am" and "git apply" and
they indicated that there were some errors.  If it's not much trouble
at all, could you resend it after a "git format-patch"?
On Mon, Jun 29, 2015 at 6:51 PM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> On Mon, Jun 29, 2015 at 6:25 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>> Attached is a patch file with
>> the changes that I think properly init the UART.
>> Still struggling a bit with git...
>> I cloned a fresh version, then update files.
>> Then I *thought* I could run "git format-patch".
> When I used git format-patch to prepare the patches before submission,
> I had to specify the range of commits.
> So to create a patch of the previous commit, it would be "git
> format-patch HEAD~1".
> Or in a more general form "git format-patch HEAD~N" where N is the
> number of previous commits.  As a result, this will create patches for
> the N previous commits.
> I still have a lot to learn about git, so I know that there are
> numerous other options that can fine tune what and how the patches are
> created.
>> It did nothing.  :-(  Gotta go read more.
>> Meanwhile, this is just the output of git diff; hopefully
>> enough for you to apply them.
> Ok, I am applying the diff right now.
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
