patches
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Jun 30 03:40:32 UTC 2015
Ok, so it turned out that somehow during my attempt to apply the
patch, it created the updated files based on the diff.  I cloned the
newly updated uMon repositiory and then added the updated files based
on the patch.
After building uMon and installing the boot.bin on an uSD as  MLO with
the appropriate headers, attempting to boot still results in the same
situation as before.
I will be taking a more closer look at the issue including the updated
files from the diff.
On Mon, Jun 29, 2015 at 7:29 PM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> Hi Ed,
> git could not apply the patch.  I tried "git am" and "git apply" and
> they indicated that there were some errors.  If it's not much trouble
> at all, could you resend it after a "git format-patch"?
> On Mon, Jun 29, 2015 at 6:51 PM, Jarielle Catbagan
>> On Mon, Jun 29, 2015 at 6:25 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>> Attached is a patch file with
>>> the changes that I think properly init the UART.
>>> Still struggling a bit with git...
>>> I cloned a fresh version, then update files.
>>> Then I *thought* I could run "git format-patch".
>> When I used git format-patch to prepare the patches before submission,
>> I had to specify the range of commits.
>> So to create a patch of the previous commit, it would be "git
>> format-patch HEAD~1".
>> Or in a more general form "git format-patch HEAD~N" where N is the
>> number of previous commits.  As a result, this will create patches for
>> the N previous commits.
>> I still have a lot to learn about git, so I know that there are
>> numerous other options that can fine tune what and how the patches are
>> created.
>>> It did nothing.  :-(  Gotta go read more.
>>> Meanwhile, this is just the output of git diff; hopefully
>>> enough for you to apply them.
>> Ok, I am applying the diff right now.
>>> umon-devel mailing list
>>> umon-devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
