enqueue/dequeue in mbuf.c
Eric Norum
eric at skatter.USask.Ca
Wed Apr 29 16:22:06 UTC 1998
"erik.ivanenko" <erik.ivanenko at utoronto.ca> wrote:
> Just a quick question...
> Should the enqueue/dequeue routines be protected by a _ISR_disable
> and _ISR_enable pair? I'm worried about this situation:
> task B at priority X ( or higher ) is waiting for an event
> task A is a preemptible task of priority X that uses the
> enqueue/dequeue primitives of mbuf.c
> an interrupt fires
> task A yields control to the ISR
> the ISR issues the event to wake task B
> task B then becomes runnable, and is of higher or equal priority of
> task A
> task B then runs, and uses enqueue/dequeue primitives
> Is that possible?
Don't worry.
Be happy.
There isn't a problem.
The situation you describe ``can't happen''. A task which wishes to
execute network code must first obtain the network semaphore
(rtems_ka9q_semaphore) so there's no chance that two tasks can be
active in enqueue/dequeue at the `same' time.
Have a look at the c/src/lib/libka9q/NOTES for complete details. By
using a mutex like this I was able to remove all interrupt
disable/enable pairs from the KA9Q network code.
This is why there's the caveat that interrupt service routines must
not call network code!
Eric Norum eric at skatter.usask.ca
Saskatchewan Accelerator Laboratory Phone: (306) 966-6308
University of Saskatchewan FAX: (306) 966-6058
Saskatoon, Canada.
