bug in termios?
joel at oarcorp.com joel at oarcorp.com
Fri Aug 21 12:38:11 UTC 1998
On Fri, 21 Aug 1998, Thomas Doerfler wrote:
> first of all: Thanks to Eric Norum for the termios support in RTEMS
> (and for KA9Q aswell!).
And for replacing it with the FreeBSD TCP/IP stack. Which is much
faster and has easy to understand licensing with no problematic
restrictions!!!
> Now the bad news :-<
Not that bad.  I found this and fixed it which working on a BSP.  The fix
just did not get back before beta3.
> - anybody already experienced this bug?
> - is it a bug at all or did I do anything fundamentally wrong?
> - is there already a common bugfix for that?
Yes. No. Yes.
> I don't like poking around in other people code, as long as I am not
> absolutely sure, what I do...
In situations like this the simplest thing is to change malloc() to
calloc().
> is there a sample device driver using "termios" together with
> XON/XOFF support? I found some definitions for XON/XOFF, but as
> far as I understand, termios will NOT manage that (up to now :->?)
> and I will need XON/XOFF for my application...
Eric will have to answer this specifically.  But I think termios handles
the SW flow control and it is up to the device driver hooks to
specifically provide handlers for HW RTS/CTS flow control.
Patch to termios.c initialization is attached.
--joel
Joel Sherrill                    Director of Research & Development
   Support Available             (205) 722-9985
Index: termios.c
RCS file: /usr1/rtems/CVS/rtems/c/src/lib/libc/termios.c,v
retrieving revision 1.19
diff -c -r1.19 termios.c
*** termios.c	1998/07/28 16:49:36	1.19
--- termios.c	1998/08/21 12:37:10
*** 206,212 ****
  		 * Create a new device
! 		tty = malloc (sizeof (struct rtems_termios_tty));
  		if (tty == NULL) {
  			rtems_semaphore_release (ttyMutex);
  			return RTEMS_NO_MEMORY;
--- 206,212 ----
! 		tty = calloc (1, sizeof (struct rtems_termios_tty));
  		if (tty == NULL) {
*** 219,225 ****
  		tty->minor = minor;
  		tty->major = major;
- 		tty->refcount = 0;
  		 * Set up mutex semaphores
--- 219,224 ----
*** 250,255 ****
--- 249,256 ----
  			rtems_fatal_error_occurred (sc);
  		tty->rawOutBufHead = 0;
  		tty->rawOutBufTail = 0;
+ 		tty->refcount = 0;
+ 		tty->rawOutBufState = rob_idle;
  		 * Set callbacks
