bsp HOWTO (fwd)
joel at oarcorp.com
joel at oarcorp.com
Fri Oct 30 15:02:35 UTC 1998
I accidently sent this to the new machine.
---------- Forwarded message ----------
Date: Thu, 29 Oct 1998 19:38:27 -0600 (CST)
To: Brendan Simon <brendan at dgs.monash.edu.au>
Cc: rtems-list <rtems-list at oarcorp.com>
Subject: Re: bsp HOWTO
On Sat, 31 Oct 1998, Brendan Simon wrote:
> When I compiler rtems I used "./bit powerpc" then "./bit_rtems
> powerpc". As I understand it the latter command generates all
> appropriate BSPs. When I compile a program does it automatically
> include one of these BSPs ? If so, which one.
If you use the provided Makefile templates, then you set
RTEMS_MAKEFILE_PATH to point to the BSP you want. See the hello_world
example.
FYI ./bit_rtems CPU BSP will only build 1 BSP. :)
I have to build the m68k this way. It takes too much disk space.
> I need/want to write a BSP for our board. Is there a howto or example
> for doing this. I need to specify where ROM and RAM live, what the ROM
> and RAM sizes are. Are these appropriate for a BSP or is it more
> appropriate to put this in a linker script ?
Geoffroy Montel wrote an initial cut at a BSP howto. I am in the process
of enhancing it.
Information of this type is usually put in the linker script.
--joel
Joel Sherrill Director of Research & Development
joel at OARcorp.com On-Line Applications Research
