M68K Support in Rtems 4.5.0 Beta1c
David J. Fiddes
D.J at fiddes.surfaid.org
Thu Apr 6 22:19:46 UTC 2000
-----Original Message-----
From: David J. Fiddes [mailto:D.J at fiddes.surfaid.org]
Sent: 06 April 2000 22:38
To: Steven Johnson
Subject: RE: M68K Support in Rtems 4.5.0 Beta1c
Hi,
>The tree I'm seeing is
>/c/src/libcpu/m68k/
> /68040/
This is just the floating point support library required for the 68040 to be
fully IEEE fp compliant (I forget the spec no ;). The _real_ m68k CPU
support is found in c/src/exec/score/cpu/m68k. Beta 4.5 runs fine on my
ColdFire boards :)
The RTEMS directory structure takes a bit of getting used to (and it's
change quite a bit from 4.0) but it does make sense eventually. The
exec/score directory contains the source to the core executive including all
of the different CPUS.
hope thsi helps,
Dave
