Setting build parameters for a sub-tree of RTEMS sources
John M. Mills
jmills at tga.com
Mon Apr 24 14:33:18 UTC 2000
Nick,
On Mon, 24 Apr 2000 Nick.SIMON at syntegra.bt.co.uk wrote:
> 'Fraid I don't know the answer to John's question, but I'm most concerned
> about problems with 'volatile' - can anyone shed any light on this?
I don't know how general might be the problems, but the specifics are:
1) I am using Joel's 'rpms' for the sh-rtems toolset, essentially
gcc-2.95.2, I believe. I have not observed other problems with these
tools. (Thanks, Joel.)
2) I am staying close to Ralf Crosepius' SH-1 BSP, which provides macros
to read and write on-chip register. For example:
'c/src/exec/score/cpu/sh/rtems/score/sh_io.h' defines:
'#define read8(addr) (*(volatile unsigned8 *) (addr))'
so a line like:
'temp8 = read8(SOME_ONCHIP_REG);' should try to read the named byte.
My typical code then goes on to set and clear bits, then rewrites the
register from 'temp8'.
I was failing to set some registers when (in gensh2.cfg) I used:
CFLAGS_DEBUG_V= -O1
while the were being set successfully by:
CFLAGS_DEBUG_V= -O4
Declaring 'volatile unsigned8 temp8;' had no effect on the failure.
I found the problem with enabling serial output, but I must assume it
could be affecting my other hardware setup routines.
I haven't tried to see what '-O1' really implies, but it seems very
aggressive with this processor ('-m2'), and does produce very compact
executables. (A "_Good_Thing_"[TM]). It just seems toxic to my hardware
setup. !(A "_Good_Thing_"[8-(])
I can send anyone snippets of the assembly-language results for the SCI
registers; they're pretty short, but I didn't think they would be of
general interest for such a specific case.
Thanks -
John Mills
Sr. Software Engineer
TGA Technologies, Inc.
100 Pinnacle Way, Suite 140
Norcross, GA 30071-3633
e-mail: jmills at tga.com
Phone: 770-441-2100 ext.124 (voice)
770-449-7740 (FAX)
