Setting build parameters for a sub-tree of RTEMS sources
Nick.SIMON at syntegra.bt.co.uk
Mon Apr 24 14:05:35 UTC 2000
'Fraid I don't know the answer to John's question, but I'm most concerned
about problems with 'volatile' - can anyone shed any light on this?
TIA,
-- Nick Simon
> -----Original Message-----
> From: John M. Mills [mailto:jmills at tga.com]
> Sent: 24 April 2000 14:57
> To: RTEMS Discussion List
> Subject: Q: Setting build parameters for a sub-tree of RTEMS sources
> Hello -
> I would like to set two flags to specific values below a
> certain point in
> my source tree, while allowing '$RTEMS_BSP.cfg' to control
> them elsewhere.
> This is in order to avoid inappropriate optimization when I access
> hardware registers. I have not been successful with 'volatile'
> declarations, I have found optimization levels which work, and I would
> still like to apply higher optimization levels to the rest of
> the source
> tree.
> In my case these flags are 'CFLAGS_OPTIMIZE_V' and
> 'CFLAGS_DEBUG_V'. I see
> in the root of this specific sub-tree that 'aclocal.m4' conditionally
> redefines 'CFLAGS', which presumably contains my two flags.
> The particular branch is: 'c/src/lib/libbsp/sh/gensh2',
> though my question
> is a general one.
> Can anyone suggest how to modify such a part of 'CFLAGS' so I
> force the
> optimizaton levels I want?
> Thanks -
> John Mills
> Sr. Software Engineer
> TGA Technologies, Inc.
> 100 Pinnacle Way, Suite 140
> Norcross, GA 30071-3633
> e-mail: jmills at tga.com
> Phone: 770-441-2100 ext.124 (voice)
> 770-449-7740 (FAX)
