About porting gen68360 BSP to our target
Aaron Xinhuan Liu
xliu at csr.UVic.CA
Tue Apr 25 09:39:31 UTC 2000
Thank you for your help.
The target we use supports BDM, but we cannot use it now. There is ftp-like
server aplication built into the target in flash memory, so we can download
our applications to the target. The images to be downloaded must conform to
the following specifications:
. The first long word contains the initial stack pointer.
. The second long word contains the absolute entry point to the image.
. The second long word contains the magic number.
. Should an image require copying to RAM, it must reside above 0x430000.
Also, I have built gdb 4.17 for the target, but I don't know how to use it for
our target.
Any suggestions ?
Aaron.
Eric Norum wrote:
> Aaron Xinhuan Liu wrote:
> > Hi there,
> > I'd like to port the gen68360 BSP with RTEMS to our target and get the
> > helloWorld program to work on our target. I have just modifed the files:
> > start.s, init68360.c, console.c and linkcmds for our target. The
> > configuration of the target is:
> > 33 MHz clock rate MC68EN360
> > Flash memory, 2 MB @ 0x00000
> > DRAM 4MB @ 0x430000
> > EEPROM, 32kB @ 0x800000
> > DPRBASE @0x8000000
> > console serial port on SMC2
> > Ethernet interface on SCC1
> > I built the sample hello_world program and downloaded to the target, but
> > it does't work and no message display. I have attached the files I
> > modefied and created to this message. Any help would be apprecaited.
> Are you using gdb/BDM? If so, the first thing I'd try is to modify the
> scripts to set up the m360 registers to the same values set by the
> initialization code. Then see if you can read and write memory with gdb
> and see if DRAM properly holds its contents. Next step is to download
> the executable and use breakpoints/single step to see if you're getting
> through the initialization properly -- pay particular attention to the
> code that copies the data segment and clears the bss segment. It's easy
> to make mistakes in the linker configuration file that causes problems
> here. Your way of laying out memory is significantly different, so my
> first guess is that this is where you're having problems.
> Then put a breakpoint on Init and see if you're getting that far.
> If things still aren't working, try putting breakpoints in the console
> output routines -- try polled output then interrupt-driven output.
> This procedure has never failed me :-)
> Eric Norum eric at cls.usask.ca
> Canadian Light Source Phone: (306) 966-6308
> University of Saskatchewan FAX: (306) 966-6058
> Saskatoon, Canada.
