4.5.0-beta2
Serrae at tsainc.com
Wed Apr 26 21:59:06 UTC 2000
Jim,
I encountered the same problem while building for i386-elf; my work around
was to cd to @prefix@/tools/build-i386-elf-rtems and
do `ln -sf i386-rtemself/c c' as soon as i386-rtemself/c was created. It
fixed the problem and I have got and RTEMS image. Bye.
-efren-
Efren Serra
Software Engineer
Systems Solutions Group
Transaction Systems Architects, Inc.
218 South 108th Avenue
Omaha, NE 68154
Phone: 402-697-2267
FAX: 402-333-9725
James Housley
<jim at thehousl To: rtems-users at oarcorp.com
eys.net> cc:
Sent by: Subject: 4.5.0-beta2
housley at theho
usleys.net
04/26/00
04:41 PM
I am having trouble with -beta2. I have downloaded:
binutils-2.9.5.0.24-rtems-20000207.diff
binutils-2.9.5.0.24.tar.gz
c_build_scripts-4.5.0-beta2.tgz
gcc-2.95.2-rtems-20000106.diff
gcc-2.95.2.tar.gz
newlib-1.8.2-rtems-20000131.diff
newlib-1.8.2.tar.gz
rtems-4.5.0-beta2.tgz
I untared and patched binutils, gcc and newlib and c_build_scripts and
that went fine. I then did a ./bit m68k and they all compiled and
installed with out a problem. I then untared rtems-4.5.0-beta2.tgz.
This is where I start having problems.
./bit_rtems m68k
or ./bit_rtems m68k efi332 both produce the same error:
gmake[3]: Nothing to be done for `install-exec-am'.^M
gmake[3]: Nothing to be done for `install-data-am'.^M
gmake[3]: Leaving directory
`/usr/home/housley/tools/build-m68k-rtems/tools'^M
gmake[2]: Leaving directory
gmake[1]: Leaving directory
Making install in c^M
cd: can't cd to c^M
gmake: *** [install-recursive] Error 1^M
ERROR: failed gmake install.^M
exit: Illegal number: ./bit_rtems^M
The problem is it is trying to use build-m68k-rtems/c instead of
build-m68k-rtems/m68k-rtems/c and I have tried all sorts of hacking to
make it work, and have failed.
Jim
Unix is very user-friendly. It's just picky who its friends are.
