Undefined reference to rtems_bsdnet_config
Hoang Ngo
hngo at caspiannetworks.com
Wed Aug 2 20:12:24 UTC 2000
I ran into a problem linking tcl8.4 lib with rtems. The error messages is
/opt/rtems/bin/powerpc-rtems-gcc --pipe -B/opt/rtems//mcp750/lib/ -specs
bsp_spe
cs -qrtems -g -Wall -ansi -fasm -O4 -mmultiple -mstring -mstrict-align
-mc
pu=750 -Dmain=rlchk -L /opt/rtems//mcp750/lib -o o-optimize/rlchk
o-opt
imize/init.o o-optimize/tclAppInit.o /opt/rtems//mcp750/lib/no-dpmem.rel
/opt/
rtems//mcp750/lib/no-mp.rel /opt/rtems//mcp750/lib/no-part.rel
/opt/rtems//mcp75
0/lib/no-signal.rel /opt/rtems//mcp750/lib/no-timer.rel
o-rtmon.rel -ltcl8.4 -lm -lnetworking -lrtemsall -lnetchip
/opt/rtems/powerpc-rtems/bin/ld: region CODE is full (o-optimize/rlchk
section .
rodata)
/opt/rtems/powerpc-rtems/bin/ld: section .data [00003000 -> 0000bc0b]
overlaps s
ection .text [00003000 -> 000f603f]
/opt/rtems/powerpc-rtems/bin/ld: section .got2 [0000bc0c -> 0000bc83]
overlaps s
/opt/rtems/powerpc-rtems/bin/ld: section .fixup [0000bc84 -> 0000bc8b]
overlaps
section .text [00003000 -> 000f603f]
/opt/rtems/powerpc-rtems/bin/ld: section .got [0000bc8c -> 0000bc9b]
overlaps se
/opt/rtems/powerpc-rtems/bin/ld: section .sdata [0000bca0 -> 0000c4df]
overlaps
/opt/rtems//mcp750/lib/libnetworking.a(rtems_glue.o): In function
`rtems_bsdnet_
initialize':
/home/hngo/rtos/rtems/tools/build-powerpc-rtems/powerpc-rtems/c/mcp750/libne
twor
king/rtems/../../../../../../rtems-4.5.0-beta3a/c/src/libnetworking/rtems/rt
ems_
glue.c:207: undefined reference to `rtems_bsdnet_config'
I have tried adding various libs in the linking stage but none works. Any
suggestions?
TIA,
Hoang
