i386-rtems
Damjan Lampret lampret at opencores.org
Tue Aug 15 10:27:19 UTC 2000
On Tue, 15 Aug 2000, Ralf Corsepius wrote:
> No. Having the cross tools (i386-rtems-gcc etc.) in $PATH is
> correct.
> This is what I am using:
OK. I have the same.
> --prefix=<directory> specifies the directory where a packages (here:
> RTEMS) gets installed to when invoking 'make install'.
> The issue I was talking about is that a native gcc has
> /usr/local/include in its default include-path by default. Therefore
Ralf, I understand what you are talking about. Although I was talking
about --prefix-program (which is very different from --prefix) but if I
shouldn't be using --prefix-program then it is okay. I didn't use it.
regards,
Damjan
