Problems Installing binutils 2.9.5.0.24
Stefaan Verschuere
stefaan.verschuere at intec.rug.ac.be
Fri Aug 25 08:54:21 UTC 2000
Hello,
I'm trying to install the GNU cross development environment for RTEMS on winNT.
I've downloaded the 'Getting Started with RTEMS for C/C++ Users' manual.
I followed the instructions in chapter 9 but I ran into following problems:
1) when I use the dos2unix commmand on ChangeLog I get:
C:\rtems\tools\BINUTI~1.24\bfd>dos2unix changelog
Dos2Unix: Can't stat 'changelog'
Does this mean anything or should I just ignore it?
2) I then continue with the configure command (using i386-go32 as target).
But then I get this:
checking whether ANSI C string concatenation works... yes
: command not found.5.0.24/ld/configure:
/tools/binutils-2.9.5.0.24/ld/configure:
'tgt: line 16: syntax error near unexpected token `in
'tgt: line 16: `case "${targ}" in
updating cache ../config.cache
creating ./config.status
creating Makefile
creating po/Makefile.in
creating config.h
Configuring gas...
: command not found.5.0.24/gas/configure:
/tools/binutils-2.9.5.0.24/gas/configure: line 81: syntax error near
unexpected
'oken `do
'tools/binutils-2.9.5.0.24/gas/configure: line 81: `do
Configure in /build/binutils/gas failed, exiting.
Is there anyone who could help me on this?
Thanks,
Stefaan Verschuere
University of Ghent, Belgium
INTEC
