Running RTEMS samples on MCP750
Hoang Ngo hngo at caspiannetworks.com
Wed Aug 30 17:16:31 UTC 2000
I ran into the same problem before and someone else
helped me, so i guess it's pay back time. Here we go:
- There is a script called psim-gdb somewhere in the
src tree. Use that to run your prgs.
Hope that helps.
Hoang
-----Original Message-----
Sent: Wednesday, August 30, 2000 8:31 AM
To: rtems-users at oarcorp.com
Cc: assers at pappa.space.se
Subject: Running RTEMS samples on MCP750
We've successfully built RTEMS for the powerpc MCP750, but the samples
won't run the way we expected. Should it be possible to do the following?
If not, how should it be done?
 cd mcp750/samples
 ppc-gdb hello.exe
 (gdb) target ppcbug /dev/ttyS1
 (gdb) load
 .entry_point_section    : 0x00000000 .. 0x00000004
 .text   : 0x00003000 .. 0x0001e4cc
 (gdb) run
For us the processor dies after run, and must be reset.
Stefan Asserhäll
PS. This is probably a VERY stupid question...
-- Stefan Asserhäll, Saab Ericsson Space, SE-405 15 Göteborg, Sweden
-- Tel: +46 31 7354332 Fax: +46 31 7354000 E-mail: Stefan.Asserhall at space.se
