RTEMS PPP stack
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Aug 3 21:38:08 UTC 2000
Rosimildo da Silva wrote:
> I might need to do some work with a PPP connection to
> Windows machines initially, and later linux.
> I would appreacite if somebody ( Eric !!! ), could tell
> me the state of the PPP stack under RTEMS.
> + Is it being tested with Windows NT ?
> + Where should I start ?
I can't answer the NT question but I can say that
although it has been made to work by others, its
configuration and intialization are not where
they should be. It is a port of off-the-shelf
PPP code so the core PPP code itself should be OK.
I think there is a dialer and example modem driver.
Ideally, it would be layered so you could use
standard termios drivers.
Basically, it is there and could stand some use
and improvement on integration.
> Thanks.
> Rosimildo da Silva rdasilva at connectel.com
> ConnectTel, Inc. Austin, TX -- USA
> Phone : 512-338-1111 Fax : 512-918-0449
> Mobile: 512-632-7579
> Company Page: http://www.connecttel.com
> Home Page: http://members.xoom.com/rosimildo/
joel at OARcorp.com On-Line Applications Research
