RTEMS PPP stack
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Fri Aug 4 05:18:55 UTC 2000
Hello to all,
> Rosimildo da Silva wrote:
> > I might need to do some work with a PPP connection to
> > Windows machines initially, and later linux.
> > I would appreacite if somebody ( Eric !!! ), could tell
> > me the state of the PPP stack under RTEMS.
I have done major reworks to the PPP sources available in RTEMS, with
the aim of a more general adaptation to the actual hardware drivers.
I have a private configuration more or less up and running...
My modifications included:
- separating the PPP device driver from the hardware dependent code
- adding "line discipline" support to termios
- adding task-driven mode to the termios serial driver model
There is still a bug my the task-driven driver model code, (and I am
VERY short in time currently) therefore I did not yet feed back a
patch.
Nevertheless I have a configuration with rtems-4.0.0 runing connected
to WinNT.
Configuration of the PPP connection (dial strings etc) is not very
elegant now, I did not modify this compared to the sources found in
the current snapshots.
I can send you a snapshot of the package, but would like to finish my
changes before giving it back to the public....
Bye,
Thomas.
> > + Is it being tested with Windows NT ?
> > + Where should I start ?
> I can't answer the NT question but I can say that
> although it has been made to work by others, its
> configuration and intialization are not where
> they should be. It is a port of off-the-shelf
> PPP code so the core PPP code itself should be OK.
> I think there is a dialer and example modem driver.
> Ideally, it would be layered so you could use
> standard termios drivers.
> Basically, it is there and could stand some use
> and improvement on integration.
> > Thanks.
> > Rosimildo da Silva rdasilva at connectel.com
> > ConnectTel, Inc. Austin, TX -- USA
> > Phone : 512-338-1111 Fax : 512-918-0449
> > Mobile: 512-632-7579
> > Company Page: http://www.connecttel.com
> > Home Page: http://members.xoom.com/rosimildo/
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
