OR1K tools
Damjan Lampret
lampret at opencores.org
Mon Aug 14 19:58:06 UTC 2000
On Mon, 14 Aug 2000, Rosimildo da Silva wrote:
> Ok,
> I have tried to compile the toolset under my CygWin environmnet:
> + NT 4.0 SP5
> + CygWin 1.1.2
> Results:
> 1. Compiling the Simulator:
> + Configuration fails, if it is not done in the same directory as
> source resides. ( ./configure ... )
Needs some fixing, yes.
> + libreadline library not found. Under CygWin readline.a is
> not installed.
> Compiled with the version that came with insight 5.0.
> Simulator compiled and linked OK. It seems to reach
> some error when executing 'testbench/dhry.or32'.
Looks like something is wrong with COFF routines (I wrote them in a hurry,
really ugly). Anyway try to load "assembly" files. Like
testbench/dhry.or32.s. Also you can try to load testbench/uos/uos.or32
(but this one is also coff).
> 2. Binutils
> + Do we have elf support ? It seems to support coff only now.
Coff only so far. Is coff enough for a start?
> + It seems to be already configured.
> + ./configure --target=or32 --prefix=/gcc-or32
> + compiled and installed Ok.
OK.
> + error during compilation:
This one was already fixed but the patch got lost somewhere. I'll do it
again.
regards,
Damjan
