stacking of rtems_clock_tick?
Fri Aug 18 14:19:09 UTC 2000
"Aaron J. Grier" wrote:
> sp tests 11, 14, 22, and 24 are all bombing out with
> _Thread_Dispatch_disable_level is (0) not 1
> any ideas?
Which version of RTEMS are you using?  This integrity check was fairly
recently added and some tests tried to print from context switch
user extensions which ended up violating this.
Where is the failure?
>   Aaron J. Grier   |    Frye Electronics, Tigard, OR   |   aaron at frye.com
>    "Cthulhu for President. Why settle for a lesser evil?" -- Matt Minnis
