rtems-4.5.0-beta3a corrupt ?
    Denis Rouleau
    roule at cyberus.ca
    Fri Aug 18 20:42:28 UTC 2000
Thanks José but I have just about a gig left! and no quotas enforced....
Any other ideas?
Regards,
Denis
  ----- Message d'origine -----
  De : Sturniolo Jose
  À : Denis Rouleau
  Envoyé : Friday, August 18, 2000 3:56 PM
  Objet : RE: rtems-4.5.0-beta3a corrupt ?
  Hi Denis!,
          I think that you have a Hard Disk space problem, due to I installed the same GZ file without trouble. I saw the same messages when the HD is running out of space. I think that will need 40 or 50 MBytes free at least.
      Good Luck,
              Jose.
  -----Original Message-----
  Sent: Viernes 18 de Agosto de 2000 15:34
  To: RTEMS mailing list
  Subject: rtems-4.5.0-beta3a corrupt ?
  Importance: High
    All,
            I'm just starting to install rtems on a new Linux machine.
    I've managed to install the RPMs but I can't unpack the RTEMS source files due to what appears to be corruption in the archive.
    Here is what I get if I run tar in verbose mode
    <snippet>
    rtems-4.5.0-beta3a/c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.c
    rtems-4.5.0-beta3a/c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h
    tar: Skipping to next file header
    tems-4.5.0-beta3a/c/src/tests/itrontests/itronmbox01/itronmbox01.doc
    tems-4.5.0-beta3a/c/src/tests/itrontests/itrontime01/itrontime01.doc
    tems-4.5.0-beta3a/c/src/tests/sptests/sp27/sp27.doc
    tems-4.5.0-beta3a/c/src/tests/sptests/sp28/sp28.doc
    tems-4.5.0-beta3a/c/src/tests/sptests/sp29/sp29.doc
    gzip: stdin: invalid compressed data--crc error
    tar: Archive ../archive/rtems-4.5.0-beta3a.tgz EOF not on block boundary
    tar: Error is not recoverable: exiting now
    [root at Linuxbox_1 tools]#
    <end snippet>
    I've verified the size on the OAR site and it matches my archive
    <archive size on my box>
    [root at Linuxbox_1 tools]# ls -l ../archive/rtems-4.5.0-beta3a.tgz
    -rw-r--r--   1 denis    denis     6964882 Aug 19 02:01 ../archive/rtems-4.5.0-beta3a.tgz
    <OAR site file size>
    06/13/2000 04:26PM      6,964,882 rtems-4.5.0-beta3a.tgz
    <tar version>
    [root at Linuxbox_1 tools]# tar --version
    tar (GNU tar) 1.13.11
    Copyright 1988, 92,93,94,95,96,97,98, 1999 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Written by John Gilmore and Jay Fenlason.
    I am running redhat Linux 6.1 on a brand new machine.
    Any suggestions?
    Thanks in advance.
    Denis Rouleau
    Senior Embedded Software Designer
    Innocor Ltd.
URL: <http://lists.rtems.org/pipermail/users/attachments/20000818/ebd53494/attachment-0001.html>
