_Context_Switch call
Ahmet Akkas
akkas at lucent.com
Mon Aug 28 18:18:50 UTC 2000
Joel Sherrill wrote:
> Ahmet Akkas wrote:
> > Hi,
> > Could you please tell me why Context Switch routine is called at
> > the beginning of the multitasking? The following is the sequence
> > of the calls until _Context_Switch() is called. Thanks in advance.
> > in ...(board)/startup/main.c
> > rtems_initialize_executive_late( bsp_isr_level );
> > in .../exec/sapi/src/exinit.c
> > _Thread_Start_multitasking();
> > in .../exec/score/src/threadstartmultitasking.c
> > _Context_Switch( &_Thread_BSP_context, &_Thread_Heir->Registers );
> Exactly. :)
> What you are seeing is that the state of the CPU at initialization
> is saved into "_Thread_BSP_context" so RTEMS can return to the
> BSP's exit code when rtems_shutdown_executive is invoked (see exit()).
> Guessing ahead .. you have executed this far and are getting a
> falt of some sort inside the 1st context switch. Here are common
> culprits :):
> + Since this is the first time you are switching TO a task, it
> is the 1st time a context YOU initialized is being loaded.
> So you may have initialized the context incorrectly. You
> may also have simply restored it incorrectly.
Yes, your guess is right. There are a couple things need to be fixed
in the initialization. Thanks,
> + You may have enabled interrupts in the restore portion of the
> switch. Prior to this call interrupts are off. This is where
> interrupts get enabled for the first time. If the board is
> generating an unexpected interrupt, then it happens when you
> enable interrupts (restore processor status/controls register).
> > Ahmet
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Ahmet
