ARM - problem with configure
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 29 18:01:01 UTC 2000
I just tried this in the development source under Linux with no
problems.
That does not mean anything about the snapshot or Cygwin.
My favorite trick in this case is to add a "set -x" near the top of
the file and watch whaat really happens.
"Andrew N. Sloss" wrote:
> Hi all,
> I'm attempting to build a bare BSP for ARM and I'm hitting a
> fundamental problem with configure. I'm using:
> Cygwin: 1.1.4
> OS: Windows 2000
> When I attempt to "make all" the process starts and after
> sometime it reaches the configure file in the following
> directory:
> /c/src/exec/score/cpu/arm/ configure
> At this point the following error message appears:
> <path>/c/src/exec/score/cpu/arm/configure: 526: Syntax error: ")"
> If I take a look at line 526 it doesn't include ")". Does anyone
> have any ideas or advice about how I could get around this problem
> or debug it. I have checked to see if I have mounted everything in
> binary mode etc.
> Any help or advice would be appreciated,
> thanks,
> -- andrew
joel at OARcorp.com On-Line Applications Research
