ARM - problem with configure
Andrew N. Sloss Andrew.Sloss at arm.com
Tue Aug 29 17:41:31 UTC 2000
Hi all,
I'm attempting to build a bare BSP for ARM and I'm hitting a
fundamental problem with configure. I'm using:
	Cygwin: 1.1.4
	OS: Windows 2000
When I attempt to "make all" the process starts and after
sometime it reaches the configure file in the following
directory:
	/c/src/exec/score/cpu/arm/  configure
At this point the following error message appears:
	<path>/c/src/exec/score/cpu/arm/configure: 526: Syntax error: ")"
If I take a look at line 526 it doesn't include ")". Does anyone
have any ideas or advice about how I could get around this problem
or debug it. I have checked to see if I have mounted everything in
binary mode etc.
Any help or advice would be appreciated,
thanks,
-- andrew
