RTEMS Snapshot ss-20001219 Available
Wed Dec 20 13:16:06 UTC 2000
ftp://ftp.oarcorp.com/pub/rtems/snapshots/rtems/current
The big changes are:
 + the mips jmr3904 simulator BSP is now running most tests.
   The benchmark timer and tm27 support need some work but it
   looks like everythign is running OK.  This BSP should work
   on any Toshiba TX390x board.
 + score/mips got a lot of tinkering. interrupt processing
   debugged for non-nested interrupts.  Many assembly routines
   are now C macros.  More application control over interrupt
   vectoring.
 + mips cache management code is there but stubbed.
 + sim68000 BSP now runs hello world.  Juan has been working
   on this -- Thanks.
 + The initial "tar fs" is now in.  The result turned out to be
   a magic IMFS loader that makes the IMFS point to the file contents
   in the tar image rather than malloc memory for it.  Saves
   a lot of memory when linking with tar images to get base file
   system images.
