RV: Multiuser environmnet
correo at fernando-ruiz.com
Wed Dec 20 22:04:58 UTC 2000
-----Mensaje original-----
De: Fernando RUIZ CASAS (E-mail) [mailto:fernando.ruiz at ctv.es]
Enviado el: lunes, 18 de diciembre de 2000 19:47
Para: 'Rtems-Users (E-mail)
Asunto: Multiuser environmnet
I am working around a multiterminal environment.
I need manages remote terminals (like telnetd) but
I have a little problem.
The shell task starts with a termios io-device
I open a new stdin,stdout & stderr with the new device.
(Only fopen, I can't freopen...)
All works well but:
The prompt shows the currentdir like Linux.
The system store this in a GLOBAL variable
rtems_filesystem_current (and umask also).
When a user exec chdhir all the users in the systems changes.
I find in libc that with a extension all the global variables are
moved at reentrants variables with impure_ptr (_REENT).
All of this will be easy if the enviromnet fs variables are pointers and
not GLOBAL VARIABLES.
With a little rtems extension is possible to give a pretty solution.
Is it possible think about of this?
Is there a best solution to avoid it?
Thanks in advance.
Anybody interested about of this?
The idea is to make a monitor (more user frienly, think linux) in every
termios terminal.
This runs ok already.
With a litle telnetd server (easy) is possible build a complex remotely
system managed.
20-12-2000
I am working to build a remote multiuser environment.
With a owner packet system of network I can make now the
same service (in order to run commands) that telnet.
Simultaneously I can move memory, exec remote commands, etc...
My final objective is a tcp/ip environment with a flash
filesystem.
Your comments about of cache memory to simulate hard-disk are
very appreciated but my idea is that the flash has not arm nor disk.
I don't need a cache memory to simulate unix only a sector erase buffer
to mantain double access (read write). The flash memory is only to
store configuration files and new version programs and logs. Not is a ram
memory. But I need to use it like ram memory in order to record the
information.
I have a /dev/flash that works very well.
What is the place for this kind of things in RTEMS? (I want contribute with
this)
and Xicor e2prom /dev/e2p, etc...
Now returning at the last e-mail.
What is the possible solution for the first problem?
I need patch base_fs.c in libc.
-------------- base_fs.c ------------------------
Here I need convert rtems_file_system current into
__rtems_file_system_current and
rtems_filesystem_current_p=(...*)&__rtems_filesystem_current;
after in imfs.h define
(I think that this is right. I write you in Windows. I dont have the sources
here)
-------------- IMFS.H --------------------
#define rtems_filesystem_current (*(rtems_filesystem_current_p))
(and more variables like umask, etc..)
to make a compatible RTEMS patch.
In a new extension like libc.c every time in task switcher changes the
global pointers at the new malloc'ed variables in every environment created.
All tasks point to global variable except if a new user session shell
environment
is created where a new memory is malloc'ed and its pointers is changed every
time
that the shell task gains the control.
I can mantain several sessions of ftp (or my owner file server) with
several current_directories (one per session).
But I need find a snapshot that contains this because everytime that
I download the new snapshot I need make a fine work to build it all again.
This type of solution is neutral to RTEMS.
I dont know all the candidates to be maked pointer in lieu of static
variables.
Thanks for all.
Fernando RUIZ CASAS
