[RTEMS]RTEMS suitable only for control system?
Sturniolo Jose
jsturnio at nec.com.ar
Fri Dec 1 23:31:17 UTC 2000
Jeffrey,
I think that is a good RTOS for general use, including
Networking.
We are using RTEMS for a "networked" device, acting as an small router
(between LAN/TCP/IP and 3 links PPP).
Before to use it, We performed a lot of tests in the network side:
- Congestion of packets, Pings from diferent machines with different packet
size during 3 days, etc.
All the test were okey.
I'm using IPFORWARDING, adding route entries, setting default router, etc.
However,I think that RTEMS has a lack for services, like TELNET, but We
replace it with a pseudo-telnet (bahh..., a echo server really).
I think that the better way to get your answer, is to download and to test
it personally, testing your desired items.
Regards.
-----Original Message-----
Sent: Viernes 1 de Diciembre de 2000 17:37
To: RTEMS mail
Subject: [RTEMS]RTEMS suitable only for control system?
Hi all:
Some one said that RTEMS is better suitable for control system not for
network product. Its design for network part is not fully supported and
tested. Is that correct ? Thanks in advance.
Sincerely,
Jeffrey Wu
