Quick Help with File Resource limits on snapshot build
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Thu Dec  7 16:45:29 UTC 2000
bob wrote:
> Apologies to all for my ignorance. I have just about ported the latest
> snapshot to our 68360 BSP but now I get the following errors when RTEMS is
> starting up after building any net application (such as the Beta 3 netdemo
> example program):-
> Can't bring scc1 up: Too many open files in system
> Can't set default route: No such process
> No routes!
> Create socket.
> RTEMS: Can't create socket: Too many open files in system
> RTEMS: fatal error, exiting
> I guess I need to allocate some file descriptor resources - I have just
> downloaded the IMFS manual but not read it yet (that's homework for
> tonight).
> Any quick help much appreciated :)
How about...
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
I don't think you need the full IMFS filesystem which requires
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> Bob Wisdom
