SH Question
Fernando RUIZ CASAS correo at fernando-ruiz.com
Fri Dec 29 21:49:05 UTC 2000
> -----Mensaje original-----
> De: joel [mailto:joel]En nombre de Joel Sherrill
> Enviado el: viernes, 29 de diciembre de 2000 22:01
> Para: rtems-users at OARcorp.com
> Asunto: SH Question
> I am trying to reduce the duplication between sh7032 and sh7045 in the
> libcpu code.  In particular, I believe it should be possible to have
> a single copy of the context switch and interrupt dispatching code.
> But I have run into a routine that I can't figure out how portable
> it really is .. so how portable is the routine
> sh_set_irq_priority()?
> I am leaning toward creating "shared", "sh1", and "sh2"
> subdirectories.
> I would also think that the /dev/null driver could be moved to a
> non-SH directory.
> Comments, suggestions?
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
Hi, Joel.
I am Fernando.
/dev/null is for a simulated link to console because the hard links are not
present
when Ralf(?) writed it. (I suppose)
/dev/null is better to place it with /dev/stub in (?).
I have a termios driver terminal for sh console.
I have two ports /dev/sci0 and /dev/sci1 and a HARD LINK /dev/console into
/dev/sciX.
The sci drivers works with interrupts very well.
Perhaps the moment to update it?
Have you hardware to probe it the changes?
I can probe it into sh7032.
Are you interested in updates?
Happy new year at all rtems-users
