RTEMS graphics
Erwin Rol
erwin at muffin.org
Sat Feb 5 19:56:46 UTC 2000
This is probably more a question for the RTEMS list, but
still of interest of the microwindows list too.
What are the costs of the ioctl/open/close lib io functions
compared to the "native" RTEMS device driver interface ?
What does it do to the memory footprint ?
Wouldn't it be more apropriate to implement the FB interface ontop
of the RTEMS device driver interface ?
- Erwin
Greg Haerr wrote:
> : Let's keep this very simple. We need to define an interface
> : for the graphics driver to match MicroWindows requirements.
> : interface fb_for_microwindows
> Great. Almost perfect.
> : /* Selects the mode of the graphics subsystem */
> : fb_set_mode()
> This may not be needed, it could possibly be merged
> with fb_init().
> : /* Get the UserMode address of the framebuffer device */
> : fb_get_fbaddr()
> This doesn't need another entry point, it can be returned by
> the fb_get_screeninfo() above. But that means that
> you'll make a kernel->user memory mapping just by opening
> the device. You might want to have another entry point,
> like this one, do that.
> : /* Basic operational services of the graphics subsystem */
> : fb_drawpixel()
> : fb_readpixel()
> : fb_drawhorzline()
> : fb_drawvertline()
> Drop these. They definitely don't belong in the kernel, or you'll
> have to include drivers for every framebuffer type. That's
> what Microwindows is for.
> : All we have to do is define the signature and data-structures
> : required by this functions.
> Yep. Take a look at /usr/include/linux/fb.h for the main
> ones to do with fb_get_screeninfo.
> : open( "/dev/fb_svga", .. );
> This should probably just be generic, i.e. /dev/fb0.
> : ioctls( fd_no, FB_GET_INTERFACE, &driver_table );
> No, here just use
> ioctl(fd, FB_GETSCREENINFO, &table);
> or
> ioctl(fd, FB_GETPALETTE, &table)
> etc for each function above. The kernel driver in RTEMS
> cases on the FB_XXX value under the ioctl switch.
> : To make a comparation to C++, the driver table returned would be like a
> : pointer to C++ instance with a public interface as define above.
> Don't bring pointers to kernel driver functions into user mode, just
> case on ioctl values as explained above.
> Regards,
> Greg
> To unsubscribe, e-mail: nanogui-unsubscribe at linuxhacker.org
> For additional commands, e-mail: nanogui-help at linuxhacker.org
