GCJ: undefined reference
Bryce McKinlay
bryce at albatross.co.nz
Wed Feb 9 11:09:47 UTC 2000
Oscar Martinez de la Torre wrote:
> Also it complained about libgcj.specs, so:
> touch /opt/rtems/sparc-rtems/lib/libgcj.spec
> Must I compile and install libgcj library?
> Or is it yet in a RPMs?
You must install libgcj, which is not yet included in the gcc distribution.
Using class libraries from kaffe will not work. If a libgcj RPM was not
provided with the RTEMS gcc rpms you are using, you will have to build (and
port?) libgcj yourself. See http://sourceware.cygnus.com/java/ for more
information.
regards
[ bryce ]
