GCJ: undefined reference
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Feb 9 11:26:16 UTC 2000
Oscar Martinez de la Torre wrote:
> Hello!
> I'm studying gcj for ERC32 processor using RTEMS and I've installed
> this RPMs.
> venus:~$ rpm -q -a
> sparc-rtems-binutils-990901-1
> sparc-rtems-gcc-gcc2.95.2newlib1.8.2-1
> sparc-rtems-gdb-4.18-1
> sparc-rtems-gcj-gcc2.95.2newlib1.8.2-1
> sparc-rtems-objc-gcc2.95.2newlib1.8.2-1
> But I can NOT see any libgcj.
The rpms only contain those parts which are distributed with gcc, newlib, gdb
and binutils. libgcj is not part of these packages.
> Must I compile and install libgcj library?
Yes. Actually, you probably will have to port it to rtems.
As there already are several people working on java for RTEMS, somebody
already might be working on this.
> Or is it yet in a RPMs?
No -- At least not as part of OAR's RTEMS' rpms.
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
