Please: Help!!!
Serrae at tsainc.com
Mon Jan 24 15:08:57 UTC 2000
Hello folks,
I have been trying to get RTEMS-4.0.0 going with the above setup on a
SPARC+Solaris2.6 with all the GNUpackages. The following
compilation `bit_rtems sparc' fails with this output:
/export/home/u1/eserra/projects/rtems/egcs-1.1.2-binutils-2.9.1-newlib-1.8.2/spa
rc-rtems/sparc-rtems/lib/libc.a(makebuf.o): In function `__smakebuf':
/export/home/u1/eserra/projects/rtems/tools/build-sparc-tools/sparc-rtems/newlib
/libc/stdio/../../../../../src/newlib/libc/stdio/makebuf.c(.text+0x128):
undefin
ed reference to `_isatty'
collect2: ld returned 1 exit status
make[4]: *** [o-erc32/hello.exe] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory
`/export/home/u1/eserra/projects/rtems/tools/build-sp
arc-rtems/c'
make: *** [all] Error 1
eserra at sun250$
Any help is greatly appretiated; also when I try this compilation
`sparc-rtems-gcc -o hello hello.c' gives me the following warning:
rc-rtems/sparc-rtems/bin/ld: warning: cannot find entry symbol start;
defaulting
to 00010074
where hello.c is:
int main() {
printf("hello, world!\n");
return 0;
Thanks.
PS After I do `sparc-rtems-gcc -c hello.c' a hello.o is generated but
hello.c is EMPTY! What is that all about?! Please, shed some LIGHT!!!
Sincerely,
Efren
Efren Serra
Software Engineer
Systems Solutions Group
Transaction Systems Architects, Inc.
218 South 108th Avenue
Omaha, NE 68154
Phone: 402-697-2267
FAX: 402-333-9725
