Snapshot 20000104 failed under CygWin 20.1
Emmanuel Raguet
raguet at crf.canon.fr
Thu Jan 6 12:16:53 UTC 2000
Rosimildo da Silva wrote:
> I need more coffee to continue tonight...
> I guess I found the problems.
> There are 2 problems:
> pc386/start/start16.S
> -- somebody left a comment open in the routine delay() "eating"
> the return. This drove me nuts for while.
> pc386/startup/ldsegs.S
> -- the jump to _load_segments() from start() never returns with
> the code in 20000104 snapshot. I guess this new delay() is devil. -:).
> I have replaced these two files with my old ones from rtems-19991117
> and I have got cdtest to work so far. What a pain, jesus !!!.
> I guess somedoby was poking around with the "delay()" routine
> and caused a few problems.
> Do you know what was being solved here ?
> None of the changes made sense to me.
I had the same problems. Now it works with these corrections :
- pc386/start/start16.S : I have closes the comment.
- pc386/startup/ldsegs.S : in delay(), the 'ret' command
must be after the #endif
Emmanuel
| Emmanuel RAGUET |
_ | CANON CRF - Communication Dept. | _
/ )| Tel: +33(0)2 99 87 96 47 |( \
/ / | Fax: +33(0)2 99 84 11 30 | \ \
_( (_ | _ http://www.crf.canon.fr _ | _) )_
(((\ \>|_/ )_________________________( \_|</ /)))
(\\\\ \_/ / \ \_/ ////)
\ _/ \_ /
