_Interrupt_Manager_initialization() routine
Ahmet Akkas akkas at lucent.com
Mon Jul 3 18:58:36 UTC 2000
Joel Sherrill wrote:
> The stack is allocated in the supercore routine
> _ISR_Handler_initialization in
> the file c/src/exec/score/src/isr.c.
Sound good. Thanks.
> Not to be picky but the SPARC port was already in RTEMS.  Do you mean
> that you have written a new BSP for RTEMS?  Or have you added support
> for a new SPARC CPU model?
Sorry for the confusion. I did not use the correct word. It is already ported
sparc. I wanted to say I build RTEMS for sparc using all existing
code. I did not do anything special to sparc. I've got my coffee :)
Ahmet Akkas
