Dwloading to target using GDB
gerke.kok at tpa-nl.com gerke.kok at tpa-nl.com
Mon Jul 24 07:32:37 UTC 2000
Hello,
we are using RTEMS for 68360 to. Can you provide us with the 68k stub for a
68360 CPU? We could use a debugger here. The stub is not standatrd I belive?
Thanks,
Gerke
> -----Original Message-----
> From: Gus Paolone [mailto:gus.paolone at fujitsu.com.au]
> Sent: Thursday, July 20, 2000 01:40
> To: Rtems
> Subject: Dwloading to target using GDB
> Hi All;
> I have GDB 4.18 with the RTEMS patches on a Linux platform (I used the
> RPMs actually). I also have the 68k stub for a 68360 CPU which I've
> tested using a terminal program and operates correctly.
> My difficulty is that when I download a program to the target it seems
> to  be too slow. I have a 38400bps serial link.
> When I do this from gdb in a WinNT (using Cygwin) it is much
> faster. Is
> there a way to speed things up? I also noticed that gdb
> writes 16-bytes
> of code data at a time. I've tried both the "set remotewritesize" and
> "set binarydownload" commands but no joy. Any ideas?
> Thanks in advance for any help anybody could provide.
> Gus
