Rate Monotonic Problems
CARERI/SED
careri at public.sta.net.cn
Wed Jun 14 09:05:35 UTC 2000
Hi,
We have built rtems for target i960, and got it work on the board.
We found there is problem in the case:
1.Define the TICK as 20ms.
2.Use a rate monotonic of 2 ticks in a task to insure that the task would be completed in 40ms
But the task consumes 53ms actually , and the rtems_rate_monotonic_period returns "status" RTEMS_SUCCESSFUL., there are NO TIMEOUTs.
And I can only explain it as following:
Whe the rtems_rate_monotonic_period returns the Counting-Tick is 2, though the real time is 53ms, but it has not reached 60ms (3 ticks), so it return SUCCESSFUL, and meanwhile it set the Counting-Tick to 0, and so on.
Am I wrong? and What's your explanation?
Sincerely,
Su Wenming
