Help!the problem of buliding GNU CROSS Compiler toolset.
Zhou qing guo zhouqg at lzu.edu.cn
Sat Jun 17 06:38:51 UTC 2000
Hi,
When I biuld the GNU Cross Compiler Toolset on linux.I do accoeding the
manul.All is ok.But whaen I run "./bit i386", the error is come: (I hope
that you could give me a hand)"
 ../../../../../src/newlib/libc/signal/signal.c: In function `_raise_r':
../../../../../src/newlib/libc/signal/signal.c:172: `NSIG' undeclared
(first use in this function)
gmake[3]: *** [signal.o] Error 1
gmake[3]: Leaving directory
`/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib/libc/signal'
gmake[2]: *** [signal/lib.a] Error 1
gmake[2]: Leaving directory
`/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib/libc'
gmake[1]: *** [libc/libc.a] Error 2
gmake[1]: Leaving directory
`/home/kinggo/rtems/tools/build-i386-tools/i386-rtems/newlib'
gmake: *** [all-target-newlib] Error 2
ERROR: **** FAILED **** base build (step 1)
Started:   Sat Jun 17 13:53:58 CST 2000
Finished:  Sat Jun 17 14:01:19 CST 2000
Directory size information:
42721   build-i386-tools
18      /usr/local/rtems/egcs-1.1b-binutils-2.9.1-newlib-1.8.0/i386-rtems
The src and build-i386-tools subdirectory have NOT been removed.
