Q: Any experience building *-rtems-gdb with Insight?
John Mills "jmills at tga.com" at tga.com
Tue Jun 20 14:55:29 UTC 2000
Hello,
I would like to try the Insight GUI for 'gdb' (aka 'tkgdb', I think) to
work on RTEMS through 'gdb' stubs in a target board's FLASH.
I expect it is preferred to use the RTEMS-patched version of 'gdb'.
I would have started by (1) building my desired version of '*-rtems-gdb'
as a learning exercise, then grafting or linking that patched source
directory into the 'insight' tree and trying a generic
configure/make/install cycle.
Question: Has anyone built this type combination? Is that the way to go
about it?
TIA,
   Mills
   John Mills
   Sr. Software Engineer
   TGA Technologies, Inc.
   100 Pinnacle Way, Suite 140
   Norcross, GA 30071-3633
   e-mail: jmills at tga.com
   Phone: 770-441-2100 ext.124 (voice)
          770-449-7740 (FAX)
