GDB
Daniel Talayco dtalayco at broadcom.com
Tue Jun 20 16:41:27 UTC 2000
One problem may be your version of patch.  I had a similar problem w/ patch under Solaris until I _upgraded_ to gnu patch 2.5.  If the patches aren't applied right, I don't think it recognizes the powerpc-rtems target.
-Dan
Erwin Rol wrote:
> Hallo all,
> i have a question to the source files of GDB on the FTP site.
> I can't build --target=powerpc-rtems with the .tar.gz archive
> because configure ends up saying that there is no such
> target in ./gdb/
> and i also can't aply the patch thats in the same dir on the ftp
> site, because it rejects on about every file.
> now my question.
> are the .tar.gz archives on the FTP site the original unpatched
> archives or are that already prepatched.  If they are patched
> could someone change the names of the archives to be different from
> the original , for example something with _rtems_ in it.
> And if they are patched why aren't they patched with the patch that is
> in the same dir of the ftp site?
> thanx,
> Erwin
>         Q - S O F T - E N G I N E E R I N G
>      Rodachtalweg 11, 81549 Muenchen, Germany
> Erwin Rol (Software Engineer)     phone: +49-89-68050051
> Erwin.Rol at Q-Soft-Engineering.com  fax  : +49-89-68050052
