summary of configuration default changes
gerke.kok at ascom.nl gerke.kok at ascom.nl
Wed Jun 21 12:26:30 UTC 2000
Hello,
just a stupit question: where should I define these defaults? And at what
time? When I compile my own program or when I build RTEMS?
wkr,
Gerke
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Wednesday, May 24, 2000 16:36
> To: rtems-users at OARcorp.com
> Subject: summary of configuration default changes
> I want to be upfront and explicit about these so no one gets
> surprised.  Together, these make the configuratin generated
> by confdefs.h pretty lean.  The maximum number of devices
> could be leaner and probably something else, but this
> is a bit improvement.
> Significantly lowered the default memory requirements:
>     - CONFIGURE_RTEMS_INIT_TASKS_TABLE was 10 now 0
>     - CONFIGURE_POSIX_INIT_THREAD_TABLE was 10 now 0
>     - CONFIGURE_ITRON_INIT_TASK_TABLE was 10 now 0
>     - CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS was 20 now 3
>     - added CONFIGURE_NUMBER_OF_TERMIOS_PORTS and defaulted to 1
>     - added CONFIGURE_TERMIOS_DISABLED defaulted to "enabled"
>     - miniIMFS is now the default
> Added configuration error checks that:
>   + Ensure > 0 tasks/threads are configured
>   + Ensure at least one inititalization task/thread is defined
> bsp.h now defines these so BSP specific requirements
> are accounted for.
>   + CONFIGURE_NUMBER_OF_TERMIOS_PORTS
>   + CONFIGURE_INTERRUPT_STACK_MEMORY
> console_reserve_resources and rtems_termios_reserve_resources
> are no longer required and considered obsolete.  Calls to
> rtems_termios_reserve_resources have been eliminated although
> the routine is still there and the body "if 0'ed".
> We are very close to having NO reason to modify the
> configuration tables in the BSP.  Be warned that eventually
> we would like to see the need for BSP_Configuration
> eliminated!
> Our long-term intention is to move interrupt stack size from
> the CPU Table to an application level configuration parameter.
> This will make it easier for an application to change the
> interrupt stack size.
> Similarly, we have talked about letting the application set
> their own task minimum stack size.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
