The Probelm about build RTEMS4.5,
    Ralf Corsepius
    corsepiu at faw.uni-ulm.de
    Wed Jun 21 09:55:16 UTC 2000
Zhou qing guo wrote:
> Hi,
> I download the pakeage of thr RTEMS4.5,
> 1.Installing RPMs,that is ok!
> (rtems-base-binutils-2.9.5.0.24-1,rtems-base-gcc-gcc2.95.2newlib1.8.2-7,
> rtems-base-gdb-4.18-4,rtems-base-gdb-4.18-4,i386-rtems-binutils-2.9.5.0.24-1,
> i386-rtems-gcc-gcc2.95.2newlib1.8.2-5,i386-rtems-gdb-4.18-4)
> 2,Building RTEMS:Unpack the RTEMS Source,is ok!
> when Generate RTEMS for a Specific Target and BSP:
> #./bit_rtems i386 i386-rtems
> The errors is :
> checking whether to enable maintainer-specific portions of
> Makefiles... no
> checking if cpu i386 is supported... yes
> checking for make/custom/i386-rtems.cfg... configure: error: no
> configure: error: ../../../rtems-4.5.0-beta3a/c/configure failed for c
> Could not successfully configure into build-i386-rtems!
> Could you help me?
If you already have the rpms installed, there is no need to run bit
or bit_rtems.
Instead, this should be sufficient:
1) Make sure to have the cross-tools in $PATH:
PATH=/opt/rtems/bin:$PATH
2) Build rtems:
mkdir build
cd build
<path>/rtems-4.5.0-beta3a/configure --target=i386-rtems [more
options]
make RTEMS_BSP="<bsps to be build>"
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
