trace() conflict in RTEMS and ncurses.
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jun 1 19:59:50 UTC 2000
OUTWATER wrote:
> OOPS! - should have looked at the source! Looks like trace() is in the
> webserver code...
My grep turned that up before your second message showed up.
But my reply did not beat yours. :)
> Again the question - which package to modify?
I think it would be best to change the webserver to use goahead_trace.
Personally, I think it is bad form to use such common names and both
should be changed. I don't see trace() as part of the defined public
API to curses.
Out of curiousity what was under-configured from your earlier email.
And be warned trace mode in ncurses appears to write a file named
"trace" in the current directory so you will lose another
file descriptor.
> Keith
joel at OARcorp.com On-Line Applications Research
