trace() conflict in RTEMS and ncurses.
    OUTWATER
    vac4050 at cae597.rsc.raytheon.com
    Thu Jun  1 20:37:29 UTC 2000
Joel -
Not sure what you mean by "under configured"...
As for renaming trace() to goahead_trace in the web server code - done.  See
attached patch.
As for the trace file in the CWD, actually I was hoping to get the trace file to
debug my original pesky problem - no output at all to my console port when I try
to run the ncurses tests.
Keith
> OUTWATER wrote:
> > OOPS! - should have looked at the source!  Looks like trace() is in the
> > webserver code...
> My grep turned that up before your second message showed up.
> But my reply did not beat yours. :)
> > Again the question - which package to modify?
> I think it would be best to change the webserver to use goahead_trace.
> Personally, I think it is bad form to use such common names and both
> should be changed.  I don't see trace() as part of the defined public
> API to curses.
> Out of curiousity what was under-configured from your earlier email.
> And be warned trace mode in ncurses appears to write a file named
> "trace" in the current directory so you will lose another
> file descriptor.
> > Keith
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
Desc: web.diff
URL: <http://lists.rtems.org/pipermail/users/attachments/20000601/b2341480/attachment-0001.obj>
