Building RTEMS on Sparc
Ahmet Akkas
akkas at lucent.com
Tue Jun 6 19:11:24 UTC 2000
I created sys-include directory manully as Frank suggested.
It has not reached the point it failed (still running). So
I will let you know the result soon.
Thanks,
Ahmet Akkas
Joel Sherrill wrote:
> Frank Szczerba wrote:
> > If you create the directory it is complaining about:
> > # mkdir /home/akkas/gnu_tools_for_RTEMS/sparc-rtems/sys-include
> > the build should succeed. It doesn't seem to need any files in that
> > directory
> Yes. This is a valid workaround.
> The purpose of the sys-include directory is to manually insert
> "foreign" .h files into the build process. Say you were building
> a Linux->Solaris (unix->unix) cross compiler. You could grab the
> native Solaris .h files and put them in sys-include.
> > Frank Szczerba
> > Development Engineer
> > Woodward McCoach Inc
> > frank at wmi.com
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
