Building Coldfire 5307 BSP under 4.5-beta3?
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jun 8 23:35:29 UTC 2000
"David J. Fiddes" wrote:
> Hi,
> >I've not found the mailing list archives on the new web site, so I
> >guess I'll have to waste some mailing-list bandwidth and ask: are
> >there any patches that need to be applied to David Fiddes' SBC5307 BSP
> >in order for it to build on 4.5-beta3?
> The BSp that is on my website is horribly out of date. I have a much more up
> to date one that *should* work with beta3 but is currently misbehaving. I've
> broken something in the libc initialisation or heap size determination that
> causes all mallocs to fail...so whilst most of the sample apps work not much
> else does.
> I can let you have a copy in a few days (if you can live with broken
> code)...but it will take many weeks for me to find the time to fix the code
I don't know if you took advantage of the cleanup across the m68k BSPs
and sharing off a lot of code. See what is in libbsp/m68k/shared
and watch out for the updated linkcmds/bsp_specs.
> sorry,
> Dave
joel at OARcorp.com On-Line Applications Research
