mvme167 patch for rtems-4.5.0-beta1c
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Mar 8 14:45:11 UTC 2000
Charles-Antoine Gauthier wrote:
> Enclosed is a patch that solves a number of problems with the MVME167
> port and that cleans up a few things.
> Joel: With the addition of the network driver, we had to run bootstrap.
> This caused a number of trivial changes to the Makefile.in files et al.
> Also, our version of automake must be different from yours. The results
> are slightly different (automake 1.4 gave similar output, automake 1.4a
> was quite different, which makes me think that your version is a much
> older 1.4a than the one I have). I recommend that you rerun bootstrap on
> our files with your tools just for consistency.
This is a known problem with Redhat and other Redhat based distributions (AFAIK, Mandrake and Helloween have the same problem).
cf http://sourceware.cygnus.com/ml/automake/1999-12/msg00155.html
In brief: The latest official version of automake is 1.4, but some vendors package unreleased snapshots taken at some time in the past from automake's development sources.
A similar incident recently seems to have occured with autoconf where some other vendors have picked up a development version called 2.14.1 ;)
Joel uses Redhat, therefore he uses Redhat's proprietary automake-1.4a.
IMO, Joel better might consider using automake-1.4 in future ;)
Ralf.
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung (FAW)
Helmholtzstr. 16, 89081 Ulm, Germany Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de FAX: +49/731/501-999
http://www.faw.uni-ulm.de
